Date/Time: Sat, 11 Jan 2025 11:39:20 +0000
VAP api works with ES, not with CL
View Count: 770
[2016-12-01 19:38:56] |
onnb - Posts: 662 |
I have a study that uses the VAP api. It works with ES but is not getting any data with CL. Any idea why this might be? |
[2016-12-02 00:07:56] |
Are you referring to this ACSIL structure member: ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-02 00:18:22] |
onnb - Posts: 662 |
yes
[2016-12-02 00:19:59] |
It is essential that sc.MaintainVolumeAtPriceData be set to 1 in the study function in the sc.SetDefaults code block to ensure that the necessary volume at price data is being maintained for the chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-02 00:20:12
