Date/Time: Sat, 11 Jan 2025 11:55:40 +0000
Timezone of Data Export
View Count: 762
[2016-12-01 16:01:11]
User760942 - Posts: 120
Hi SC,
Is it possible to make the timezone of intraday data exported to CSV be a different timezone then UTC? Such as my local computers timezone?
I see in your documentation it exports to UTC by default, but figure they may be a way around this?
thanks
[2016-12-01 18:37:48]
If you use this command, the data is exported in the time zone of the chart:
Edit Menu: Edit >> Export Bar and Study Data to Text File
