Date/Time: Sat, 11 Jan 2025 12:39:48 +0000
Range Tick chart
View Count: 744
[2016-12-01 14:27:47] |
toews&kane - Posts: 209 |
Do you know why the current bar of the 1 tick range always is a little bit strange? It's not a tick bar, just runs randomly long Please see attached Cheers |
Private File |
[2016-12-01 19:01:45] |
When posting an image of a chart, only use this method: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Anyway we know what the problem is, refer to this section here about this: https://www.sierrachart.com/index.php?page=doc/helpdetails47.html#RangeCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-01 19:04:46
[2016-12-02 13:57:34] |
It's already set that that way, that's the way I've been using it all along, data storage in 1 tick
[2016-12-02 17:58:03] |
Therefore, there is no other reason for such a problem like this. Post an image of the chart by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-02 17:58:26
