Date/Time: Sat, 11 Jan 2025 11:57:21 +0000
Super Trend Stop
View Count: 1567
[2016-12-01 13:03:28] |
Guilherme - Posts: 66 |
Is there a documentation of how the Super Trend Stop is calculated? The technical studies reference page does not contain it. []s |
[2016-12-01 17:37:09] |
No there is not. You have to look at the actual source code. Refer to the instructions here: http://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html#SearchingSourceCodeBuiltIn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
