Date/Time: Sat, 11 Jan 2025 12:05:10 +0000
period ohlc ?
View Count: 770
[2016-12-01 02:06:33]
zippyzip - Posts: 293
i seem to get issue where it will plot yest ohlc - which is what i want , but then it will do this and plot todays ohlc , not sure if im setting it wrong , please let me know , as it happens often ,
Private File
[2016-12-01 05:49:59]
This is far too vague for us to help with and the screenshot is too complex for us to understand what it is you are trying to show.
We recommend that you thoroughly review the documentation for the study to understand how all aspects of it work:
https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s294
[2016-12-01 13:18:55]
picture is simple , its showing you how i have it set to plot yest ohlc , but on chart its plotting todays ohlc , so i was asking if there was an issue with it as few people are noticing similar thing , or is it set wrong ?
[2016-12-01 17:42:25]
This is too vague. We need very specific details. First of all an image of the chart can only be posted by the method here:
Use no other method.
There must be only one study on the chart. You need to tell us what specific lines you are referring to by making reference to the Subgraph name and color . We need to know the particular Date and Times where they are not correct and why you believe they are not correct including an explanation of the Session Times in the chart being used. We need full detail. Otherwise, we have little idea what you are talking about specifically. We are not going to make this easy. We are not going to struggle with this when we have insufficient detail and cannot figure this out.
Date Time Of Last Edit: 2016-12-01 19:10:25
[2016-12-01 20:24:55]
lol thanks for the help
[2016-12-01 20:35:22]
OK, we also did a review of post #1 again, and we can still not understand what you are showing.
Date Time Of Last Edit: 2016-12-01 20:36:03
[2016-12-02 02:39:28]
looking to plot period OHLC for prev days data , are my settings correct to do so ?
if so then something is off as u can see its plotting the current days OHLC , this is all im asking ,
put new picture in with ohlc circled , as u can see its plotting todays ohlc , with use current period set to NO
let me know if this helped anymore , idk how much easier i can explain it sorry
Private File
[2016-12-02 04:56:14]
We have greater clarity now but still not sufficient.
The reason it is not sufficient is because we did not get an image of the chart following these instructions here and cannot see all of the relevant detail:
We recommend setting Auto Skip Period of No Trading to No.
Anyway it really would be best if there still is a problem that you provide a Chartbook containing a single chart following these instructions:
What is the Time Zone that you have Sierra Chart set to?
