Date/Time: Sat, 11 Jan 2025 12:06:36 +0000
Need up with trailing stop. And question on partial filled
View Count: 722
[2016-11-30 18:58:51]
User269983 - Posts: 31
1) I need help setting up trailing stop after target 1 is met. My strategy is attached.
What I want is when target 1 is met, move to BE -9 ticks. Then the remainder of the position will be trail by 10 ticks whenever price move 10 ticks.
2) I also have a question on partial filled. Let say I have an order for 10 contracts with 5 contracts on target 1 and target 2. If only 7 contracts was filled. How will SC allocates the contracts to the target?
2a) What would happen to the BE stop when a partial filled on the target 1? Will it move to BE or it only move when the target one is completely filled?
Thanks.
Private File
[2016-12-01 05:41:27]
1. The updated Trade Window configuration file is attached to do what you want.
2. This is explained here:
http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html#Functionality
You also need to understand that in the case of 2 Targets, the parent order is separated into two separate orders:
http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html#OCOGroup
3. The move to breakeven action always occurs even on a partial fill when triggering based on a Target in the same OCO Group. The documentation has been updated to explain this.
attachmentCL-2step BE.twconfig - Attached On 2016-12-01 05:41:11 UTC - Size: 6.18 KB - 241 views
