Date/Time: Sat, 11 Jan 2025 11:53:28 +0000
Pivot Points
View Count: 812
[2016-11-30 16:16:04] |
User845035 - Posts: 4 |
Hi, I've just taken up a trial of your software and was wondering if you could advise how I apply the following pivot style to a chart? http://www.sierrachart.com/image.php?Image=1480442229527.png |
[2016-11-30 21:03:18] |
This is the Price Projection tool: http://www.sierrachart.com/index.php?page=doc/Tools.html#RetracementExpansionProjection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-01 07:23:37] |
Hi, many thanks for the tip and this looks like the tool that I'm after. However, after clicking Tools >> Current Tool Config , I only see greyed out Config # items?
[2016-12-01 07:47:20] |
If they are all disabled, it means there is no tool currently selected from the Tools menu.
[2016-12-01 15:32:42] |
Hi, I would like to know if I can program the Fibonacci Price Extension lines to my own requirements? i.e as in the example above http://www.sierrachart.com/image.php?Image=1480442229527.png |
[2016-12-01 18:31:08] |
Yes of course. Just refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/Tools.html#RetracementExpansionProjection Chart Drawing Tools: Drawing Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
