Date/Time: Thu, 16 Jan 2025 12:14:15 +0000
Addition to the Symbol Display study
View Count: 1965
[2016-11-30 14:01:01]
User885971 - Posts: 4
I'm using the Symbol Display study to print the symbol name in the background of my chart. Some symbols have weird names, and for these I'd like the ability to override what's printed. For instance, the CQG name for the Stoxx50 future is F.US.DSX. I'd rather just print "FESX". I tried using the text tool to achieve the same thing, but it's limited in font size and also it doesn't stick to the background like the Symbol display does.
https://i.imgur.com/7mn3zQW.png
Date Time Of Last Edit: 2016-11-30 14:02:23
[2016-12-01 21:07:34]
We will add a new input setting to specify alternative text to the Symbol Display study.
[2017-11-01 15:46:37]
marty_nv - Posts: 85
I love Symbol Display but I don't see it in my Transact version of 1632, but it is in my older TD Ameritrade and IQFeed version of 1575 (See attachment). Can I access it in Transact Feed 1632?
imagePat 171101-1 Symbol Display Study.png / V - Attached On 2017-11-01 15:45:23 UTC - Size: 41.58 KB - 320 views
[2017-11-01 16:19:17]
But since Transact on 1575 has Symbol Display (see attached), I don't know what I am doing wrong now. Dare I upgrade the older SC Version from 1575 to 1632?
imagePat 171101-2 Symbol Display Study.png / V - Attached On 2017-11-01 16:16:52 UTC - Size: 59.32 KB - 342 views
[2017-11-01 17:58:59]
Update to version 1633 following the instructions here:
This will resolve the problem.
Date Time Of Last Edit: 2017-11-01 17:59:09
[2017-11-01 18:08:02]
[2017-11-01 19:20:39]
3 problems that I have found with "Symbol Display" per attachment:
1. Study overlay relative to price and studies
2. Initial Horizontal Position doesn't seem to work in my Windows 7 OS.
3. Display in Fill Space doesn't display in Fill Space for me.
If you can tell me what I am doing wrong! Thank you.
imagePat 171101-3 Symbol Display Study.png / V - Attached On 2017-11-01 19:19:12 UTC - Size: 58.77 KB - 341 views
[2017-11-02 05:11:26]
1. This cannot be controlled. It is always underneath the main price graph and studies. But will see if we can add an option for this.
2, 3. Refer to the detailed documentation for the study here about these:
Symbol Display
[2017-11-02 10:41:45]
It seems that upon reboot of SC, "Display Symbol" adjusts to Fill space when asked for in input box.
In the screenshot sent, "Display Symbol" was not adjusting to fill space, though asked to do so.
Everything seems to work as you designed, greatest chart platform ever.
[2017-11-02 16:49:44]
But you need to look at the documentation for that Input to understand how it works.
[2017-11-02 18:51:29]
Thank you for the helpful documentation link, resulting in attached view at this point.
imagePat 171102-1 Symbol text display.png / V - Attached On 2017-11-02 18:48:54 UTC - Size: 49.14 KB - 312 views
