Date/Time: Sat, 11 Jan 2025 14:43:12 +0000
Multiple instruments in one Chart
View Count: 2129
[2016-11-30 12:09:48]
User693138 - Posts: 20
Hi, do you have process how to put three Instruments in one chart? First Instrument in First Chart Region,Second in second Region atc...
Kind regards
M.
[2016-11-30 20:10:17]
This is supported. Refer to:
http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#OverlayingMultipleSymbols
[2016-12-11 12:21:00]
Hello and thank you.
Unfortunately when try to set Graph Draw Type than there is Custom setting only.
How can I get option to Draw Candle Type?
[2016-12-11 19:01:53]
What is the exact name of the study that you are using?
