Date/Time: Sun, 02 Aug 2026 12:58:08 +0000
SCGraphData clarification:
View Count: 2317
| [2013-08-01 18:52:06] |
| golding - Posts: 18 |
SC, In the example below, I find a difference between: int endRefChartNdex = graphData.GetArraySize() - 1 ; int endRefChartNdex = graphData[0].GetArraySize() - 1 ; The former returns the same static results for each call to the PROCESS_AGENT_SIGNALS2, while the latter returns variable results (the desired behavior). I used the former at first since the code loops thru all subgraphs in SCGraphData , so I expect the index to be consistent for all SGs. The documentation for sc.GetStudyArraysFromChart shows use of both, first to test the SCGraphData size, then to test the SG size. Shouldn't GetArraySize return the same result for both? Am I missing something or is this unexpected behavior? thx JG ============================== Example: inline void PROCESS_AGENT_SIGNALS2( SCStudyInterfaceRef sc, int chartNum, SCGraphData &graphData, int mode, int bgColor ) { int endRefChartNdex = graphData[0].GetArraySize() - 1 ; for ( int sgNdex = 1 ; sgNdex < NUM_SIG_CNTRL_SGS ; sgNdex++ ) { sc.Subgraph[sgNdex][sc.Index] = graphData[sgNdex][endRefChartNdex] ; ====================== Documentation for sc.GetStudyArraysFromChart has the following example: SCGraphData StudyData; sc.GetStudyArraysFromChart(ChartNumber, 1, StudyData); // Check if we got the data and then get the first subgraph array from the study data if(StudyData.GetArraySize() == 0) return; SCFloatArrayRef StudyArray = StudyData[0]; if(StudyArray.GetArraySize() == 0) return; |
| [2013-08-02 11:31:07] |
This gets the number of Subgraph arrays. If the Arrays were returned, then this will be 60: graphData.GetArraySize() This gets the number of elements within a particular Subgraph: graphData[0].GetArraySize() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-02 11:31:48
