Date/Time: Sat, 11 Jan 2025 09:58:44 +0000
Screen Images - naming image before saving
View Count: 692
[2016-11-30 10:08:10] |
User553714 - Posts: 184 |
Hi, At the moment when "save chart to file" from the chart >> edit >> screen images menu the file is auto named, is there a way you can rename the file before it is saved? If there isn't, this would be a good option to have as it is much easier to name the image at the time of saving. Regards |
[2016-11-30 10:24:31] |
No, you have to manually rename it after it is saved.
