Date/Time: Sat, 11 Jan 2025 10:05:50 +0000
Text size for Chart Calculator
View Count: 975
[2016-11-30 09:16:28] |
User513662 - Posts: 90 |
Hi, I have a high resolution screen (4k) on a laptop and cannot seem to find where the text size is for the Chart Calculator. The text comes up incredibly small so you can't read it. Other tools I have managed to alter the text size within the tool. Your assistance appreciated. |
2016-11-30_4-06-24.png / V - Attached On 2016-11-30 09:15:45 UTC - Size: 114.91 KB - 212 views |
[2016-11-30 20:55:42] |
Refer to: http://www.sierrachart.com/index.php?page=doc/Tools.html#ChartDrawingText Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
