Date/Time: Sat, 11 Jan 2025 10:02:54 +0000
Visual set-up for customisation
View Count: 1021
[2016-11-30 08:17:41]
isa74 - Posts: 54
Sir,
I would like to know how to set-up 2 things:
> when you have several windows on a Chartbook, how it is possible that all the windows becomes affected when one change value to trade ?
> how it is possible to link the horizontal line with a TC1 fonction button ?
Each time I do create a horizontal line, i get the thin green line which is not what i want. I would to swicth between several line profiles.
https://gyazo.com/0647f0e0f210eaeb6c9fba6f37d91f08
Thanks !!
IB.
Date Time Of Last Edit: 2016-11-30 12:21:27
[2016-11-30 21:01:25]
We do not understand what you are referring to. What value are you referring to?
When posting an image of a chart, only follow the method here:
We will accept no external screenshots. We did not look at what you provided.
Refer to:
http://www.sierrachart.com/index.php?page=doc/Tools.html#ApplyingPredefinedConfiguration
