Date/Time: Sat, 11 Jan 2025 10:07:41 +0000
Chart inquiry
View Count: 749
[2016-11-29 22:52:14] |
User157806 - Posts: 71 |
Just want to verify if sierra charts offers the following chart type/tool? Screenshot attached for reference.
Chart function.png / V - Attached On 2016-11-29 22:51:43 UTC - Size: 585.19 KB - 241 views |
[2016-11-29 23:09:03] |
What specifically are those numbers you are referring to in the screenshot. Are they just the total volume for the chart bar?
[2016-11-29 23:12:34] |
Let me verify thank you.
[2016-11-29 23:16:42] |
Per customer The number that the arrows are pointing to. They are at the bottom/top of the candlestick numbers bar. |
[2016-11-29 23:56:45] |
OK understood, but what do they represent. The total volume for the bar?
[2016-11-30 01:53:37] |
confirmed yes Total Volume thank you.
[2016-11-30 05:12:35] |
Refer to the Study Collection at #35 on this page: Additional Files (Study Collections, Spreadsheets, Chartbooks) Also refer to the top of the page for instructions to use to Study Collection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-30 21:20:58] |
Thank you.
