Date/Time: Sat, 11 Jan 2025 10:00:54 +0000
Volume Value area lines - N Periods back output when export bar and study data
View Count: 662
[2016-11-29 22:45:17]
User17477 - Posts: 65
Hi Support,
Is there any way I can get the output from "Volume Value area lines" study to show 1 week previous (n period back = 1) when I export bar and study data to text file. I have my chart set up to show last weeks VPOC and value area lines but when I export the study it shows current weeks (developing VAL and VPOC).
cheers
[2016-11-29 23:10:55]
There should not be any problem with this at all. When you export the data, all data that you see in the chart is going to be exported.
What is in the file will be identical to the chart bars and study data you currently see.
[2016-11-29 23:15:08]
We just did a test now using this command:
Edit Menu: Edit >> Export Bar and Study Data to Text File
The Volume Value Area Lines study data did get exported properly. No problem at all.
Date Time Of Last Edit: 2016-11-29 23:15:30
[2016-11-29 23:23:28]
My apologies... Sorry I just tried this again and you are right of course.
