Date/Time: Sat, 11 Jan 2025 09:46:51 +0000
SSL error 1408F10B
View Count: 1154
[2016-11-29 15:38:16]
User529859 - Posts: 18
Socket (17) | Error reading. SSL Error: error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number | 2016-11-29 09:23:13 *
I got error message very 3 or 5 mintues, why is that? and my connection keep disconnected.
thanks
Rex
Date Time Of Last Edit: 2016-11-29 15:39:00
[2016-11-29 17:37:25]
We need to see the complete Message Log. From this we do not have enough information.
Here are instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2016-11-30 13:15:59]
Socket (11) | Error reading. SSL Error: error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number | 2016-11-30 07:12:41 *
Socket (11) | SSL shutdown indicates not able to send 'close notify'. | 2016-11-30 07:12:41
Socket (11) | SSL has been shut down. | 2016-11-30 07:12:41
Socket (11) | SSL object has been freed. SSL state is now disconnected. | 2016-11-30 07:12:41
Socket (11) | Shutdown and closed. | 2016-11-30 07:12:41
Connection to the external service has been lost. | 2016-11-30 07:12:41
AMP/TTNet | Disconnected. | 2016-11-30 07:12:42
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-11-30 07:12:42
Socket (25) | Error reading. SSL Error: error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number | 2016-11-30 07:13:07 *
Socket (25) | SSL shutdown indicates not able to send 'close notify'. | 2016-11-30 07:13:07
Socket (25) | SSL has been shut down. | 2016-11-30 07:13:07
Socket (25) | SSL object has been freed. SSL state is now disconnected. | 2016-11-30 07:13:07
Socket (25) | Shutdown and closed. | 2016-11-30 07:13:07
Connection to the external service has been lost. | 2016-11-30 07:13:07
AMP/TTNet | Disconnected. | 2016-11-30 07:13:08
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-11-30 07:13:08
[2016-11-30 16:27:31]
This is not acceptable for us. We must see the entire Message Log. This is made very clear in the documentation.
Follow the instructions here:
