Date/Time: Sat, 11 Jan 2025 23:00:49 +0000
Swing High and Low- different length to the left and right?
View Count: 673
[2016-11-29 10:16:29]
phaedonk - Posts: 352
Is it possible that the Swing High and Low indicator is made to provide two different length fields? For example, twenty bars to the left and eighty to the right?
[2017-01-11 20:43:46]
Is it?
[2017-01-11 22:31:03]
No. You would need to modify the study to do this.
Date Time Of Last Edit: 2017-01-11 22:31:22
[2017-01-11 23:09:51]
mkata - Posts: 103
phaedonk,
There is a User Contributed Study called My Swing High/Lows which will do exactly your request.
[2017-01-11 23:13:05]
Thank you very much, I'll check it out.
