Date/Time: Sat, 11 Jan 2025 09:53:18 +0000
[Programming Help] - Positioning of drawstyle graphics above/below bar
View Count: 761
[2016-11-29 06:02:15] |
billx - Posts: 1 |
Would like the drawstyle graphic to render a specified distance below or above the bar/candle. Currently it renders on the highest or lowest point on the bar/candle. Is there a subgraph property that will allow control of this? code snippet: sg.DrawZeros = 0; // false sg.GraphRegion = 0; sg.Subgraph[0].Name = "Color0"; sg.Subgraph[0].DrawStyle = DRAWSTYLE_POINTHIGH; sg.Subgraph[0].SecondaryColorUsed = 0; sg.Subgraph[0].LineWidth = 6; sg.Subgraph[0].PrimaryColor = RGB (0,0,255); //Blue sg.Subgraph[1].Name = "Color1"; sg.Subgraph[1].DrawStyle = DRAWSTYLE_POINTLOW; sg.Subgraph[1].SecondaryColorUsed = 0; sg.Subgraph[1].LineWidth = 6; sg.Subgraph[1].PrimaryColor = RGB(0,128,0); //Green sg.AutoLoop = 1; return; } // Do data processing // Array references SCFloatArrayRef High = sg.BaseDataIn[SC_HIGH]; SCFloatArrayRef Low = sg.BaseDataIn[SC_LOW]; SCFloatArrayRef Open = sg.BaseDataIn[SC_OPEN]; SCFloatArrayRef Last = sg.BaseDataIn[SC_LAST]; SCFloatArrayRef Avg = sg.BaseDataIn[SC_OHLC]; SCFloatArrayRef Out0 = sg.Subgraph[0].Data; SCFloatArrayRef Out1 = sg.Subgraph[1].Data; { if ((Open[sg.Index-2] >= Last[sg.Index-2])&& Low[sg.Index-1] < Low[sg.Index-2]&& Low[sg.Index-1] < Low[sg.Index]&& Last[sg.Index] > Open[sg.Index]) { Out1[sg.Index] = Avg[sg.Index]; sg.Subgraph[1].DataColor[sg.Index] = sg.Subgraph[1].PrimaryColor; } else Out1[sg.Index] = 0; } |
[2016-11-29 18:28:17] |
You just need to use some other Draw Style than what you are using and set the value you want it displayed at by setting that value into the corresponding element of the Subgraph Data array: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].Data[] / sc.Subgraph[][] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-29 18:28:40
