Date/Time: Mon, 03 Mar 2025 21:46:35 +0000
Save Chart Image to File - Change Location
View Count: 1532
[2016-11-29 04:42:23]
jj554 - Posts: 20
Is there a way to change the output folder when I save chart images? Currently I have to save them and then manually move them around into different folders. Is there a way to select output folder when saving the chart image?
Thanks!
[2016-11-29 05:10:22]
This can be changed through Global Settings >> General Settings >> Chart Image Folder.
[2021-11-15 04:41:25]
Refer to:
Cryptocurrency / Bitcoin Data and Trading Services: Notes
