Date/Time: Sat, 11 Jan 2025 09:48:16 +0000
Always show border around custom drawn value area + auto follow present time
View Count: 819
[2016-11-28 08:39:32] |
User885971 - Posts: 4 |
Hi, I'd like an option to always show the border around a drawn value area, like in this screenshot: https://i.imgur.com/5f3Usgp.png Without this, I have no idea when a drawn value area will stop updating. I keep noticing when it's already stopped since a few bars. Another good thing to to add would be: If I draw a profile that covers the present bar and beyond, then always follow the present time until I manually resize the area to end at a time in the past. |
[2016-11-28 17:50:13] |
You need to set this study Input to Yes: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_DrawProfileOutlineEnclosingBars You need to set this study Input to From Start Date-Time To End: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_VolumeGraphPeriodType Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
