Date/Time: Sat, 11 Jan 2025 09:48:50 +0000
Trade/chart DOM columns/lines distortions in the latest releases
View Count: 836
[2016-11-27 20:08:50] |
User11942 - Posts: 298 |
Hello SC team, I updated to 1490 this am just to find there were distortions of column widths and also gaps between certain columns background and vertical lines. Please take a look at the following screenshot: http://www.sierrachart.com/image.php?Image=1480275364185.png However, there are no such things in older versions and I rolled back to 1468. http://www.sierrachart.com/image.php?Image=148027704075.png Please advise if there are settings in new vesions to get DOM appearance back in order or this is just a new normal? Thanks. |
[2016-11-27 20:39:54] |
Work is being done on the Trade/Chart DOM columns and this is not yet finalized.
