Date/Time: Sat, 11 Jan 2025 10:04:37 +0000
Copying Spreadsheet System for Trading to another chart symbol
View Count: 686
[2016-11-26 16:42:35] |
User260310 - Posts: 6 |
I have set up a spreadsheet system for trading as a study collection for a certain symbol (CL for example). What is the proper procedure for copying the same system to a different symbol (NG for example)? If I have the chart and spreadsheet for CL open, then use the Find Symbol function to select NG, and Duplicate Active Chart, the correct studies will be applied to the NG chart, but the spreadsheet system will reference the same spreadsheet as the first chart (i.e. the CL spreadsheet). Do I then have to manually go into the settings for the Spreadsheet System for Trading study on the NG chart and enter a different spreadsheet name in order to disassociate the CL spreadsheet from the NG chart? Or is there a better way to go about this? Thanks in advance for your help. |
[2016-11-27 09:19:58] |
Have a look at the Formula Source Sheet Number input: Spreadsheet Study Inputs: Formula Source Sheet Number Without knowing the details of what you are doing, the use of the Study Collection is all you need. Once you have opened the other chart, just apply the Study Collection you previously saved containing the Spreadsheet System for Trading study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
