Date/Time: Sat, 11 Jan 2025 10:05:21 +0000
where to find SC studeies source code?
View Count: 1085
[2016-11-26 11:26:19] |
benyeh1225 - Posts: 28 |
Hi Sir, I would like to try to build my own studies. Can you advise whwere can I find source code of the following studies inside sierra chart? (1) MACD, (2) Kijun-Sen (3) Chikou Span, (4) Senkou SpanA &B Thank You Ben |
[2016-11-26 21:44:01] |
Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html#SearchingSourceCodeBuiltIn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
