Date/Time: Sat, 11 Jan 2025 09:59:48 +0000
Problems with Renko chat
View Count: 740
[2016-11-24 18:28:46]
User150435 - Posts: 17
I do not understand when I put on the schedule settings if Renko then add something menyaetsya schedule and dramatically See for yourself and help to understand what happened
imageБуфер обмена-1.jpg / V - Attached On 2016-11-24 18:28:15 UTC - Size: 144.17 KB - 231 views
imageБуфер обмена-2.jpg / V - Attached On 2016-11-24 18:28:31 UTC - Size: 175.19 KB - 297 views
[2016-11-24 22:19:16]
We do not understand the question.
However, do not use one of the Renko studies. And instead follow the instructions here for Renko bars:
Renko Bar Charts
[2016-11-25 15:21:43]
Hello. Problem display Renko chart. If you look at the screenshots you will see that on the same graphs with the same in- tended, indicators and timeframe Renko shows differently namely, if I decided to add something or just on / off platform that draws other Renko bars others understand the story?
Help me!
[2016-11-25 17:53:45]
Did you set the chart to Renko bars following the instructions here?:
Renko Bar Charts
When posting an image of a chart only use the method documented here and no other method:
