Date/Time: Sat, 11 Jan 2025 10:04:21 +0000
Time Periods
View Count: 776
[2016-11-24 14:58:19] |
User469312 - Posts: 97 |
I am looking to highlight a series of date's. I know with the Time line and Time line Highlight indicators I can find hourly/minute time periods But I am looking to highlighting specific daily periods (even weeks) Example I would like to high light on a daily chart with the periods from 10/5/2016 to 10/15/2016 and so forth. Again, these dates would not be set in stone and I would like to continue to change the dates and length of periods. May I ask Is there a way to do this? Is there a function/indicator on Sierra that I can create this? Thanking you in advance for any insight. Mike |
[2016-11-25 03:28:03] |
Use the Rectangle drawing tool: Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle You can follow the instructions here to change the particular Dates at any time: Chart Drawing Tools: Chart Drawing Properties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-25 03:29:33
