Date/Time: Sat, 11 Jan 2025 09:55:42 +0000
Difference study subgraph not displayed in spreadsheet study
View Count: 1274
[2016-11-24 13:39:25]
User560062 - Posts: 100
Hi, i created a difference study subgraph however I am trying to use a spreadsheet study to make some analysis on the values but the Study Subgraphs Difference is not visible in the spreadsheet study. Is there a way to get the data in the spreadsheet please?
Much appreciated.
[2016-11-25 03:30:34]
There must be some data displayed for the study even if it is zeros. It is impossible otherwise. You must not be looking at the correct Sheet and column if you see nothing.
If you see only zeros, then refer to:
Chart Studies: Study Calculation Precedence And Related Issues
Date Time Of Last Edit: 2016-11-25 03:31:04
[2016-11-25 05:03:35]
You are correct I should have said that it is printing zeros but the difference study has DrawZeros input set to no the issue is still not resolved.
thank you
[2016-11-25 05:09:28]
Resolution is up to you. We have given you the relevant documentation in the prior post. It is not going to help to ask us. You need to study the documentation and understand the nature of the problem. It explains this very very clearly.
[2016-11-25 07:15:08]
ok thanks
