Date/Time: Sat, 11 Jan 2025 11:53:20 +0000
[User Discussion] - Spreadsheet and replay
View Count: 833
[2016-11-24 05:37:08]
nicktrader - Posts: 725
I create the spreadsheet "OLIPOC". Every day I am writing new data in the sheet "OliMP". Sheet7 is "connected" with "OliMP" and the the are running in Chart #7 (1Day).
If I like to run a replay the data of the sheet "OliMP" do not run back. It would help, if there would be a second choice to run more than one charts back:
1. For all Charts in Chartbook
2. For selected Charts in Chartbook (in my case i.e. #1, #2, #3)
Or is there an other way to use replay and my "manual" sheet (OliMP) is going back too.
imagespreadsheet .png / V - Attached On 2016-11-24 05:24:47 UTC - Size: 21.61 KB - 275 views
[2016-11-29 03:34:24]
Is there a way to add a second option?
[2016-11-29 13:55:05]
Sawtooth - Posts: 4147
I think you need to add the OLIPOC spreadsheet to charts 1,2,3 and then reference the OliMP sheet from their sheets.
You will probably need to use the INDEX/MATCH function combination to use the correct date on OliMP.
[2016-12-01 05:22:18]
Good Morning tomgilb,
many thanks for your response. I will take a look of that but from my point of view it would be much easier, if there would be the choice to select the charts manually in the replay function.
