Date/Time: Sat, 11 Jan 2025 09:50:59 +0000
Can some percentages of VbP POC colors be transparent?
View Count: 679
[2016-11-24 00:46:52] |
User275302 - Posts: 52 |
I would like 0% - 50% to be transparent, and then designate colors for the remaining blocks of percentages. Is that possible?
POC Colors.JPG / V - Attached On 2016-11-24 00:46:32 UTC - Size: 41.64 KB - 278 views |
[2016-11-24 02:15:01] |
No.
