Date/Time: Sat, 11 Jan 2025 10:09:27 +0000
Interface zoom on footprint
View Count: 1125
[2016-11-23 14:00:27] |
isa74 - Posts: 54 |
Sir, I would like to know how it is possible to: > highligh the most important price level as shown on this image attached (the yellow rectangular surrounding on the pricing boxes) > Alerts sending precise message about all the micro divergences that can occurs if candles tend to go up but delta is negative or inverse > Which is the name of the parameters to get the numbers at the top and the bottom of each candle please ? (see attached) It would be great to have the possibility to configure that: i want messages for divergence on 1mn time chart on the last 2 candles, or 15mn on the last 3 candles, ecc. See attached graph please. Thanks ! Date Time Of Last Edit: 2016-11-23 15:03:22
sc_Sierracharts_Interface_Footprint_DG.jpg / V - Attached On 2016-11-23 14:37:25 UTC - Size: 191.49 KB - 321 views sc_Sierracharts_Interface_Footprint_EURUSD_crop.jpg / V - Attached On 2016-11-23 15:02:21 UTC - Size: 96.58 KB - 295 views |
[2016-11-23 18:52:16] |
Refer to these sections: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#ChangingBarSpacing http://www.sierrachart.com/index.php?page=doc/Scaling.html#InteractiveScalingExpandCompress Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-29 02:50:57] |
Refer to the Input settings here for Numbers Bars: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#InputSettings There are three different Highlight Input settings to accomplish this. > Alerts sending precise message about all the micro divergences that can occurs if candles tend to go up but delta is negative or inverse
For this, refer to this page: http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php You will have to create your own formula to determine this. Determining the formula is not within the scope of our support. > Which is the name of the parameters to get the numbers at the top and the bottom of each candle please ? (see attached)
Refer to the "Show Historical Pullback" Input here: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#InputSettings It would be great to have the possibility to configure that: i want messages for divergence on 1mn time chart on the last 2 candles, or 15mn on the last 3 candles, ecc.
For this, refer to this page: http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php You will have to create your own formula to determine this. Determining the formula is not within the scope of our support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
