Date/Time: Sat, 11 Jan 2025 09:52:27 +0000
pivot point, support and resistance lines
View Count: 910
[2016-11-23 13:27:21] |
User656410 - Posts: 12 |
Good morning, I have been in a trading room that uses Ninja through the Ninja broker this week. 2 days ago the pivot was .2 different, yesterday, multiple points, and now this morning it is about 2 points different. We are both using the daily pivot point. The support and resistance lines are also off. Why is that? Aren't the pivots based off the same info, regardless of platform? Thanks |
[2016-11-23 18:09:12] |
Refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails65.html There are many variables affecting Pivot Point lines calculations. You need to have a very thorough understanding of all that is involved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-23 19:24:43] |
Sawtooth - Posts: 4147 |
Also, in Sierra Chart there are 24 different pivot point Formula Types: http://www.sierrachart.com/index.php?page=doc/PivotPoints.html#PPFormulas (21-24 are not documented). Date Time Of Last Edit: 2016-11-23 19:37:01
[2016-11-24 02:27:23] |
Thanks for the info.
