Date/Time: Sat, 11 Jan 2025 10:07:31 +0000
Custom studies problems on upgrading from 1478 to 1481
View Count: 663
[2016-11-22 15:05:27] |
Zosimus - Posts: 345 |
Hi Sierra team, On upgrading from 1478 to 1481 a fee of my custom studies started generating the followin message on the log - "This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart." Any idea what could cause this? |
[2016-11-22 16:23:29] |
Rebuilding the studies on 1481 solved the problem.
[2016-11-22 17:44:12] |
OK not sure why that would have happened but if the rebuilding solves it that is good.
