Date/Time: Sat, 11 Jan 2025 09:58:47 +0000
Copy Chart Drawing question
View Count: 641
[2016-11-21 20:13:40] |
NumbersBars - Posts: 141 |
Version 1488 This is not a bug report, just trying to understand Copy Chart Drawing function. I have trend lines drawn on Hourly candle chart. And the drawings are copied to 5-min candle chart,and 20 tick Reversal bar candle chart. There is no issue with 5-min chart where all drawings are copied correctly. However, I noticed in Reversal Bar chart, it is way off. I have attached both charts for your reference. Is this the expected result when copying drawings from time based chart to reversal bar chart? Is there anything I can do to avoid this? Thanks Date Time Of Last Edit: 2016-11-21 20:40:48
Private File Private File |
[2016-11-22 05:41:09] |
Refer to this page about this: https://www.sierrachart.com/index.php?page=doc/helpdetails34.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
