Date/Time: Sat, 11 Jan 2025 09:50:57 +0000
Splitting uneven trade size using 2 targets with common stop
View Count: 815
[2016-11-21 15:10:55]
JamesP - Posts: 89
I'm using a formula within a spreadsheet for autotrading to determine order quantity while backtesting. I am also using the 2 targets with a common stop function. When the order quantity is uneven, for example 7 total quantity, the trade automatically gets split into 3 contracts for the first target and 4 contracts for the 2nd target. Is there a way to set it up so that the larger quantity is always used for the first target? Thanks.
[2016-11-21 17:25:50]
The only solution to this is to use ACSIL:
http://www.sierrachart.com/index.php?page=doc/ACSILTrading.html
This cannot be controlled through Spreadsheets.
