Date/Time: Sat, 11 Jan 2025 09:47:52 +0000
text on retracement levels
View Count: 830
[2016-11-20 22:53:29] |
User472677 - Posts: 356 |
How do I change the text on retracement levels?
[2016-11-20 23:40:48] |
What specifically do you want to change?
[2016-11-21 03:52:46] |
Font size of retracementertainment levels such as 38.2%
[2016-11-21 04:35:40] |
Refer to: https://www.sierrachart.com/index.php?page=doc/Tools.html#ChartDrawingText Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
