Date/Time: Sat, 11 Jan 2025 10:00:15 +0000
Cannot see limit orders in DOM
View Count: 808
[2016-11-20 09:00:31] |
Neshvar - Posts: 5 |
Dear SC, yesterday I have activated DOM services but I cannot see the limit orders queue. Please the attached screen where you can clearly see DOM is not functioning properly, can you please advise? Thank you in advance, Martin |
[2016-11-20 09:09:11] |
You need to add the Bid Size and Ask Size columns. Refer to the instructions here: Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-22 15:04:14] |
Thank you!!!!
