Date/Time: Sat, 11 Jan 2025 12:04:44 +0000
different volume profiles
View Count: 895
[2016-11-19 16:26:51]
canyiah - Posts: 48
How do I create volume profiles for the previous day on the right side of the chart? I have 1 profile to the right that shows all volume from start day to end date I want to add 2 more profiles to the right 1 for the previous day and the other for the last 5 days
imagevolprofile.jpg / V - Attached On 2016-11-19 16:26:39 UTC - Size: 395 KB - 275 views
[2016-11-21 18:04:28]
User968625 - Posts: 260
Has this been answered somewhere here or on a private msg? I have a daily profile on the right but not sure how to make it automatically previous day and how to add another one for rolling previous period (e.g. previous week). the only things I see is number of bars but I change between timelines often
[2016-11-21 19:21:15]
In response to post #1, these are the relevant Volume by Price study inputs:
http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_NumOfPeriodsBackToReference (set to 1 to reference the prior day)
http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_VolumeGraphPeriodType (Set to One Period at End of Fixed Time Length )
http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_TimePeriodTypeForFixedTime (set to Days)
http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_TimePeriodLengthForFixedTime (set to 1 and 5 for each study respectively)
https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_AlignToFarRight (Set to Yes)
Date Time Of Last Edit: 2016-11-21 19:22:09
[2016-11-21 19:23:04]
In response to post #2, our prior post should answer this as well.
[2016-12-09 11:08:48]
pierre94250 - Posts: 5
>Isn't that shows you a profile with the two previous days combined ?
What if I want a profile with only the last day, do you think that is possible ?
[2016-12-09 17:50:47]
Yes this is possible.
Use the Volume by Price study and use the following Input Settings:
http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_TimePeriodLengthForFixedTime (set to 1)
http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_RightAlignVolumeBars (Set to Yes)
Date Time Of Last Edit: 2016-12-09 17:51:18
