Date/Time: Sat, 11 Jan 2025 07:10:36 +0000
Background and Triangle up draw styles switched for studies
View Count: 675
[2016-11-18 18:54:44] |
User299392 - Posts: 216 |
See please if you can look into this and fix it please.
[2016-11-18 20:01:23] |
Marek F - Posts: 244 |
In my studies in the Subgraphs Settings, the DRAWSTYLE_TRIANGLEUP is displaying as the Trans. Fill Bottom, the DRAWSTYLE_TRIANGLEDOWN as the Text, the DRAWSTYLE_COLORBAR_CANDLEFILL as Left Offset Box Bottom, the DRAWSTYLE_FILLRECTTOP_TRANSPARENT as Point On Low, the DRAWSTYLE_FILLRECTBOTTOM_TRANSPARENT as Point On High. Studies work properly, the issue applies only displaying names of the DrawStyle in the Study Settings. |
[2016-11-18 20:10:09] |
SO, what should I do?
[2016-11-18 20:10:19] |
Can we have Sierra folks reply?
[2016-11-18 20:37:42] |
We know why this has happened. It will be fixed in about an hour.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-18 20:38:03
[2016-11-18 21:42:40] |
We are releasing version 1488 now which resolve this.
