Date/Time: Mon, 05 Oct 2026 17:34:20 +0000
Is there a way to reload chart data WITHOUT recalculating studies?
View Count: 1404
[2016-11-18 17:01:07]
skelcap - Posts: 139
I have a chart with custom data and a study which changes the data, so I need to reload the data after calculating the study. I tried the following but on the reload after the recalc we have sc.IsFullRecalculation == 1 to it gets stuck in an infinite loop:
if (sc.IsFullRecalculation)
sc.FlagToReloadChartData = 1;
else
sc.FlagToReloadChartData = 0;
[2016-11-18 17:39:46]
Yes this does make sense that will happen.
This is normal. A recalculation obviously must take place after reloading the chart data from the file.
[2016-11-18 21:59:12]
Ah of course, that's the way it's supposed to happen, I was getting confused. My study was recreating my DataFile with different data which took some time, so the lag on constant recalc was noticeable. I think instead I should make the study change the symbol to reference the different data.
