Date/Time: Sat, 11 Jan 2025 09:51:03 +0000
fxcm
View Count: 1467
[2016-11-18 15:17:43]
User150444 - Posts: 7
Hi, how do i go about connecting to an fxcm demo account?
Chris
[2016-11-18 17:33:00]
A FXCM trading account has now been assigned to your Sierra Chart account.
The particular account number assigned to your Sierra Chart account can be viewed on this page:
https://www.sierrachart.com/UserControlPanel.php
If this account number is one that you provided us, verify it is correct.
Update Sierra Chart to the current version following the instructions here:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
Set "Global Settings >> Data/Trade Service Settings >> Service" to "FXCM Demo Trading - DTC".
Connect to the server with "File >> Connect to Data Feed".
Depending upon when you receive this message it may take up to two minutes for our server to receive the updated authorizations for you to be able to connect.
[2016-11-18 18:21:51]
Hi, thank you for doing that!
The data im seeing is different from other software that im using, using the same data source (FXCM)! Is there possibly different fxcm connections?
Cheers
Chris
[2016-11-18 19:52:21]
Just to add to that, i trade using a tick chart (universal renko) and I'm seeing nearly double the number of bars in today's session from what I'm seeing in other software using the same data (fxcm) and the same setup. Any help or ideas would be appreciated
Cheers
Chris
[2016-11-18 20:59:02]
FXCM has different data feeds.
The data that you are receiving based upon the account assigned is considered the "Standard" account data feed. As compared to a dealing desk account data feed.
The bid and ask spreads should also be tighter.
[2016-11-19 10:32:45]
Could I potentially be put on a different fxcm connection to try?
Cheers
Chris
[2016-11-21 09:58:26]
Yes we can do that. We will get this set up for you later today.
[2016-11-21 10:51:42]
Brilliant
thank you
[2016-11-21 17:12:06]
Hi any updates on connecting me?
Cheers
[2016-11-21 19:14:18]
We need more time to set this up but it will be done today.
[2016-11-22 04:39:49]
This is still not ready for release. Please allow up to another two days.
[2016-11-28 23:03:12]
We apologize for the delay. The reason for the delay is that FXCM is still doing work on the dealing desk connections configuration.
