Date/Time: Sat, 11 Jan 2025 10:05:49 +0000
sc.OpenChartOrGetChartReference() minimised
View Count: 636
[2016-11-18 12:04:37] |
Sporken - Posts: 82 |
Hi, First, thanks for your help with my last question :) Using sc.OpenChartOrGetChartReference() Is there any way to open a window minimised? Or to minimise/restore/maximise windows once created? I cant find it in the documentation. Thanks in advance! -Jason |
[2016-11-19 21:36:02] |
This function will be added to the next release: int sc.SetChartWindowState(int ChartNumber, int WindowState); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-19 21:36:15
[2016-11-19 21:37:25] |
fantastic! thank you
