Date/Time: Sat, 11 Jan 2025 09:53:36 +0000
Suggestions of interface improvements | 11/18/16
View Count: 1053
[2016-11-18 06:53:09]
isa74 - Posts: 54
Sir,
could it be possible to:
> add a value to compare it to the initial one, for example, adding the Dowjones to a graph of the DAX and defining the colors and the level of opacity of the new compared elements ?
> to move left to right the title of each Chartbook on the top lign on the inferface, in order to place them as we want ?
> to be able to register several profil by default to call them when required by a simple click on the mouse: for exemple, one profil with 3 MM, BB, and Ichimoku and another one with other indicators with different registered names, ecc.
> to add a bookmap tools in order to check patterns, visualise the amount of contracts by level of pricing, ecc. (Depth of Market): https://bookmap.com/#about
> to add a footprint tool to see inside each candles the volume of buyers and sellers
> to add a tape tool
Thanks.
[2016-11-18 10:41:58]
1. Use the Overlay (Bar) study for this:
https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s100
2. No.
3. Refer to:
Study Collections
4. Refer to:
https://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php
5. Refer to:
Numbers Bars
6. Refer to:
https://www.sierrachart.com/index.php?page=doc/helpdetails31.html
[2016-11-18 15:58:17]
isa74 - Posts: 54
Sir,
dealing with the Depth of Field, I went on the step by step webpage but I did meet some difficulties:
1. I did not locate the symbol pattern for the Symbol I want: DAX, DOWJONES, SP500
Could you confirm me which are the right codes please ?
DAX: ???
DOW JONES DOW Utilities - Dow Jones Indices: DOWU
S&P 500: SPX500
2. How do set the volume number for each volume bar like in the example of your librairy please ? http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php
I have the bars filled with different colors (I inversed the color from cold (10% of the POC) to hot colors (near the POC)): the bars does not let appear any numbers of trade inside.
3. I would like to set up a graph such as the one attach but I do not find the paramaters to reach this goal (see attached please the VolumeByPrice_img4.jpg)
Could you tell where please ?
It would be nice to be able to upload various type of visual configuration as pre-templates in ordre to be able to discover a lot of the features of the Sierra univers !
Thanks a lot !
imagesc_Sierracharts_Vbp-panel_config.jpg / V - Attached On 2016-11-18 15:56:29 UTC - Size: 1.45 MB - 360 views
[2016-11-18 16:01:03]
isa74 - Posts: 54
This is another configuration that please me too:
https://www.sierrachart.com/image.php?Image=1307044599690.png
Thanks a lot for your explanations !
Have a nice week end !
[2016-11-20 08:00:56]
1. If you are interested in using the Market Depth Historical Graph study, you need to do this only with the futures market. For futures data, refer to:
Is Historical and Real-time Futures Data Included?
2. Refer to:
http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_DisplayVolumeInBars (Display Volume in Bars)
The documentation explains how to control the Text/Font size.
3. We do not understand what you are asking here.
4. Use the Numbers Bars study to accomplish this:
Here is the documentation for Numbers Bars:
Numbers Bars
