Date/Time: Sat, 11 Jan 2025 06:55:15 +0000
SC Single Chart Stops Responding/Windows 10 Taskbar Crashes
View Count: 650
[2016-11-18 03:34:19] |
User948528 - Posts: 108 |
Windows 10 task bar set to auto hide crashed, and became 'invisible'. Some time after, only one active trading chart window in SC became unresponsive and could not be made the active window, clicking on it did nothing as if it was not present, other SC windows functioned normallyd. Restarting SC fixed it. Rebooting entir system needed to fix task bar issue. Nothing indicated in SC message log at time of this issue. This has occurred before, is it possible it is an SC issue, or could only be related to the Windows issue? |
[2016-11-18 03:50:33] |
This definitely is not a Sierra Chart issue. We have never even heard of this before. However, if you have a problem where Sierra Chart is in a frozen state due to high CPU usage, this is the relevant help topic: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
