Date/Time: Sat, 11 Jan 2025 06:50:35 +0000
Referencing Different Time Charts not working - PLEASE HELP.
View Count: 864
[2016-11-17 15:29:43] |
User299392 - Posts: 216 |
In using Study Price Overlay, where I use it to reference higher time frames (say 4 hour) moving averages study into a 5-min chart; AND IT DOES NOT WORK ANYMORE. It simply resets the higher time chart (i.e the referenced chart, 4-hour chart in my case) to the same as the one it called from i.e. 5-min chart in my case. In other words, 4-hour chart will be turned back and be timed as 5-min chart. And both charts will be 5-min charts then. Hope you follow me here. I use this study a lot and really need help. It appears that this has happened since the below update has been added since below is the message Sierra sends out if I were to change the referenced chart back to the 4-hour chart. PLEASE, PLEASE HELP. "Added a prompt when a chart is being referenced by another chart to clear that chart reference when the user tries to change the timeframe of a chart bar and that is not possible because of the reference." INPUT VALUES USED - Match Source Bars to Destination Bars: Yes (I used NO too here and it did not work) Data Copy Mode: Use Latest Value Bar Time Matching Method: Nearest Match Copy Source Data to Latest Corresponding Destination Bar: NO Fill Blanks With Last Value: No Multiplier: 1 Draw Zeros: No Full Synchronization of Source Chart to Destination: No Use Colors from Source Study: Yes Use Styles and Widths from Source Study: Yes Always Use Short Names: Yes Use Mutlicolumn Rectangle Style For Price Bars: No PLEASE, PLEAS HELP HERE. |
[2016-11-17 17:45:43] |
This has been fixed. Update to the latest prerelease following the instructions here: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
