Date/Time: Sun, 12 Jan 2025 05:22:32 +0000
Attach Keyboard Shortcut to Study Input YesNo
View Count: 1074
[2016-11-17 14:50:07]
Pinger - Posts: 33
Hi
Is there a method of attaching a keyboard shortcut to a study Yes/No input? I would like to be able to toggle a study Yes/No input via the keyboard.
Kind regards
[2016-11-17 17:25:01]
No, this is not supported.
However, if you are developing your own custom studies, this page has methods which can be used to control study Inputs:
http://www.sierrachart.com/index.php?page=doc/ACSInteractionWithMenusControlBarButtonsPointerEvents.php
[2017-01-26 10:53:53]
In the next release it will be possible to use the keyboard to change study inputs directly from the chart window in the same way as changing the symbol of a chart.
[2017-02-04 12:07:51]
Pinger - Posts: 33
Fabulous! Thanks.
