Date/Time: Sat, 11 Jan 2025 06:58:28 +0000
Fixed gap on chart + entering trade via limit order
View Count: 581
[2016-11-17 13:13:58] |
hursthead - Posts: 28 |
Hi I have 2 questions, one on charting and another on trade order entry 1. Is it possible to have my chart gapped from the right vertical axis by a fixed distance? Attached chart for reference. 2. I have a trading system that generates a signal to enter a trade, but I wish to enter via a limit order of say 2-3ticks better, rather than entering at the market. I know this can be manually done using limit order entry, but is there a faster way to do on the trade window along with an attached OCO order? Thanks. |
Private File |
[2016-11-17 17:43:13] |
1. Refer to: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#FillSpace 2. Yes. Refer to Custom Trading Keyboard shortcuts to configure this: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#CustomKeyboardShortcuts Make sure you are on the latest version of Sierra Chart for this. For Attached Orders, refer to: http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
