Date/Time: Sat, 11 Jan 2025 06:54:06 +0000
Add rollover method to chart linking options
View Count: 691
[2016-11-17 13:03:13] |
skelcap - Posts: 139 |
Is this possible? I.e. if you have a group of linked charts and you change "Continuous Contract" option for one chart to "Volume Based Rollover" then they all change.
[2016-11-17 17:25:36] |
No, this is not supported.
