Date/Time: Sat, 11 Jan 2025 06:59:27 +0000
Error messages when transacting a trade through FXCM
View Count: 646
[2016-11-17 09:08:37] |
User169391 - Posts: 62 |
Hi Have attached a file showing messages generated when I execute a order. The order seems to get filled and I can also close the trade. Have not seen this before. Can you give some guidance as to what is happening or explain the messages? thanks. |
fxcm error sierra charts.JPG / V - Attached On 2016-11-17 09:06:52 UTC - Size: 157.6 KB - 246 views |
[2016-11-17 09:19:12] |
This is harmless and it has been resolved. Update Sierra Chart to the latest prerelease with Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
