Date/Time: Sat, 11 Jan 2025 07:08:57 +0000
ATR Indicator
View Count: 1497
[2016-11-17 04:18:06] |
User488039 - Posts: 114 |
Today the ATR averaged around 2.40 this afternoon. This may sound somewhat naive, but does the 2.40 represent points or ticks? Thanks |
[2016-11-17 04:58:16] |
The Average True Range study calculates actual values and it is not in ticks.
[2016-11-17 05:48:31] |
What I read about ATR is, they say to make your stop loss 2 to 3 times the ATR. Would that end equation be in Points?
[2016-11-17 05:53:23] |
If you are using Attached Orders in Sierra Chart, it depends upon whether you have selected Price or Ticks on the Targets tab.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-17 05:53:32
[2016-11-17 06:31:13] |
Yes, I'm using attached orders, and I have selected ticks. But I'm not sure what that has to do with my ATR issue? Here's my example: I'm trading the NQ, I have an ATR of 2.5. I'm going to take the ATR x 2 for a stop loss. Would the stop loss be 5 points? My question is... would the final answer to the equation be in Points? Becuase if it was in Ticks, the end equation would only be 5 ticks. Thanks Date Time Of Last Edit: 2016-11-17 06:34:30
[2016-11-17 07:10:47] |
Would the stop loss be 5 points? Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-17 07:18:57] |
Thank you
[2016-11-17 07:32:31] |
There is no need to say thank you. It is more burden on us.
