Date/Time: Fri, 22 Nov 2024 13:41:55 +0000
Alert shortcut on chart
View Count: 1772
[2013-04-01 16:36:06] |
umair1 - Posts: 86 |
The alerts work well in Sierra chart but I'd like to be able to enter them more quickly. For example on a chart I would like to be able to right click on a candlestick chart and be able to set an alert when the bid or ask is higher than the price under the cursor. Currently I have to read the price under cursor then go to the Alerts menu and enter the alert manually each time. If you are trading several markets and trying to keep track of when key highs and lows are invalidated then it can be a very time consuming process. See attached image for how this menu would look. |
[2013-04-01 19:36:49] |
Sierra Chart - Max - Posts: 5729 |
This is currently supported with Chart Drawing Alerts: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#Alerts Sierra Chart Support |
[2013-04-03 03:56:04] |
We are developing price Alert capability with the new Quote Board feature. This probably will be what you are looking for. This will be available soon. It will be easier to set up alerts more quickly through that.
[2013-05-21 18:11:58] |
M5amhan - Posts: 468 |
any idea when or if the quote board price alert feature will be released? thanks |
