Date/Time: Sat, 11 Jan 2025 07:57:17 +0000
AHK and SierraChart - prints hotkey letters in SC title bar...
View Count: 1120
[2016-11-16 20:48:20] |
User305145 - Posts: 38 |
Hi, I use an AHK macro that involves pressing hotkeys whilst a SC DOM is the active window (see attached image). How can I press e.g. "c" whilst the SC DOM is the active window w/o SC picking up on it and printing out the letters as per the image? /Martin |
sc_letter printing in dom.jpg / V - Attached On 2016-11-16 20:46:58 UTC - Size: 201.21 KB - 293 views Attachment Deleted. |
[2016-11-16 21:50:50] |
That is normal for Sierra Chart to do that. The active chart will receive the keyboard input and show the characters on the title bar until the enter key is pressed.
